How to use Chili with Switch
manupapet
I'm trying to use Chili Publish with Switch but it don't work.
I can't find any examples of it anywhere or documentation.
Does anyone have any examples ?
Thank you
Manu
I have lots of experience with CHILI Publisher & Switch. What type of operations were you attempting?
manupapet
I have a card visit template on chili server and an excel file.
When a drag an drop an excel file, i want switch generate pdf a file by line.
I don't find exemple on goole, website enfocus or chili publish.
Could you give me an example.
Thank you
dkelly wrote: I have lots of experience with CHILI Publisher & Switch. What type of operations were you attempting?
I assume you want to pass each row of the Excel spreadsheet to CHILI as a variable?
Switch can't process an Excel spreadsheet or even a CSV file directly. So it will not be able to read rows in spreadsheet and use information to call CHILI server to generate a PDF file.
It would be possible with a custom Switch script.
manupapet
Yes, I pass each rows of the excel preadsheet to chili variable.
I don't know that switch don't support excel file.
So, I try another idea.
thank you
dkelly wrote: I assume you want to pass each row of the Excel spreadsheet to CHILI as a variable?
With a script I wrote for convert CSV files to XML you could do something like:
manupapet
Hello dkelly,
Could you send me an example xml file please
Thank you
dkelly wrote: With a script I wrote for convert CSV files to XML you could do something like:
I'd be happy to. Please send me a copy of your spreadsheet and I'll convert it for you.
Dwight Kelly
dkelly@apago.com
manupapet
Here a link : spreadsheet
http://we.tl/2oPcu5WfGG
Thank you
dkelly wrote: I'd be happy to. Please send me a copy of your spreadsheet and I'll convert it for you.
Dwight Kelly
dkelly@apago.com
OK, the CSV2XML script created 467 XML files each containing a single record.
<order>
<PRENOM>SAS</PRENOM>
<NOM>NATURHOUSE</NOM>
<ADR>82 avenue Camille Pujol</ADR>
<CP>31500</CP>
<VILLE>TOULOUSE</VILLE>
<TEL>05 61 26 42 36 </TEL>
</order>
The CHILI configurator can then access the data to set variables using a Switch variable statement
[Metadata.Text:Path="/order/PRENOM",Dataset="Xml",Model=XML]
manupapet
Thank you to your help.
dkelly wrote: OK, the CSV2XML script created 467 XML files each containing a single record.
<order>
<CP>31500</CP>
</order>
pietvanc1
I have quite the same XML setup and after I define those variables I don't see any changes in the editor. Is there something wrong with my variables or is it just normal that the editor doesn't show changes in the editor and just apply them on the XML?
