Enfocus Community • Is there any http client on Switch 12?
Posted: Mon Sep 15, 2014 11:02 pm
by alanoliveira
Hi everyone!
Is there any way to make a http request in Switch 12 installed on a Windows 7 machine?
I have two scenarios I would like to use an http client to solve my problem.
In first one I would use a HTTP GET as a Producer.
In second I would like to make a POST with results.
The web application is out of my control, so I can't implement a SOAP webservice.
Thank you!
Posted: Mon Sep 15, 2014 11:11 pm
by dkelly
The only built-in HTTP functionality in Switch 12 is GET, Javascript function s.download(). You can use an external process such as cURL to implement other HTTP operations like PUT, POST, DELETE, etc.
Posted: Tue Sep 16, 2014 2:33 am
by gabrielp
dkelly wrote: You can use an external process such as cURL to implement other HTTP operations like PUT, POST, DELETE, etc.
That's what I do and it works really well. :D
Posted: Tue Sep 16, 2014 1:57 pm
by alanoliveira
Thank you guys!
I didn't know s.download() function, It solves a half of my problem, so i'll have to install curl to use as an external process.
Thanks again ;)
Posted: Wed Sep 17, 2014 6:04 pm
by pcobee
I use Microsofts XMLHTTP object in a Script for this all the time - mostly to retrieve graphics files from a remote service. You can implement GET, POST or SOAP with it. Works great.
