Enfocus Community • Variable watermark script
Posted: Tue Sep 30, 2014 10:33 am
by verstraete
I'm trying to make a javascript that makes a variable watermark in acrobat depending on the filename.
The watermark is a second pdf file that is generated somewhere else, but looks like the filename of the pdf where the watermark has to come.
So filename is 276297-01_V01.1-R.pdf
Watermark filename is 276297-01_V01.1-Checklist.pdf
The filename is variable (current document) and so is the watermark filename.
Script as is now.
doc = app.activeDocs[0];
doc.addWatermarkFromFile({
cDIPath: "/Volumes/PPData/Switch_HF/Checklist_Output/Checklist/276297-01_V01.1-R-Checklist.PDF",
bOnTop: false,
bOnScreen: true,
bOnPrint: true,
nHorizAlign: app.constants.align.right,
nVertAlign: 0,
nHorizValue: 0,
nVertValue: 0,
nScale: 1,
bFixedPrint: false,
nRotation: 0,
nOpacity: 1
Thanks in advance
David
Posted: Tue Sep 30, 2014 1:50 pm
by verstraete
In meanwhile I solved the problem.
var doc = app.activeDocs[0];
var docName = app.activeDocs[0].info.Title;
var p = "/Volumes/PPData/Switch_HF/Checklist_Output/Checklist/" + docName + ".pdf";
cDIPath: p,
bOnTop: false,
bOnScreen: true,
bOnPrint: true,
nVertAlign: 0,
nHorizValue: 0,
nVertValue: 0,
nScale: 1,
bFixedPrint: false,
nRotation: 0,
nOpacity: 1
