Page 1 of 2
Transferring Metadata to PrivateData
Posted: Mon Oct 06, 2014 9:32 am
by ArielRauch
I am still struggling with fetching Metadata entered via a Submit point, into privateData.
I have also problems building an appropriate fixture to test it.
Some sample parts of a script would be very helpful.
Ariel
Posted: Mon Oct 06, 2014 1:53 pm
by ArielRauch
Actually even if I work with job.getVariableAsString how do I loop through fieldlist/field[1...n]/tag?
Posted: Mon Oct 06, 2014 4:02 pm
by dkelly
You can enumerate through XML nodes using code like this:
var nodeList = theXML.getDocumentElement().getChildNodes();
for (var i=0; i < nodeList.length; i++) {
var theNode = nodeList.getItem(i);
if (theNode.getBaseName() == "ChildNode") {
var aValue = theNode.getAttributeValue( "a" );
s.log(1, "found ChildNode with attribute a=" + aValue);
Posted: Mon Oct 06, 2014 7:47 pm
by gabrielp
I think you would find it's a lot easier to just use something like this https://github.com/dominickp/SwitchWriteToPrivateData to "build metadata location path" to write it to private data. You would just have to put a hold on a folder somewhere and you can inspect the metadata in "single line text with variables". Much easier than trying to figure out the xpath or xml structure in the script, IMO.
Posted: Mon Oct 06, 2014 9:43 pm
by ArielRauch
Thank you both, Dwight and Gabriel,
I will try it tomorrow morning
Posted: Tue Oct 07, 2014 1:57 pm
by ArielRauch
getting crazy:
I put a submit point into a flow and I set "strip unique name" to no.
Afterwards I copied the path of the resulting pdf (I used two fields f1 and f2) into the fixture of incoming files for the following script:
var dataset = job.getDataset("Order");
var metadata = new Document(job.getPath());
var namespaceMap = metadata.createDefaultMap();
var jobID = metadata.evalToString("/Order/field-list/field[1]/tag",namespaceMap);
s.log(1,"aaaa");
I receive the following error message:
Libxml error 4: 'Start tag expected, '<' not found ' in file 'file:///C:/TEMP/1/FixtureTest01/inFolder2/_00001__00158_Epsilon031.pdf' on line 1
Invalid xml document C:/TEMP/1/FixtureTest01/inFolder2/_00001__00158_Epsilon #1.pdf
Only to be clear: The only metadata that is associated with the pdf is the one I entered via the submit point.
Any help is more than welcome!!!
Ariel
Posted: Tue Oct 07, 2014 2:14 pm
by tz8
use dataset.getPath() instead of job.getPath() in the new Document() part! ;)
var metadata = new Document(dataset.getPath());
Posted: Tue Oct 07, 2014 2:22 pm
by ArielRauch
This was my first approach.
This is was I received:
10/7/2014 14:21:50,Assert,Control,,,,,Libxml error 1549: 'failed to load external entity "" ' in file '' on line 0
Posted: Tue Oct 07, 2014 2:26 pm
by tz8
did you add the xml information you want in the fixture set? You need to mark the incoming job, then declare the existing datasets for a job under "Metadata datasets" otherwise you're not going to have any in SwitchScripter
Posted: Tue Oct 07, 2014 2:29 pm
by tz8
do a quick
job.log(1, job.getDatasetTags() );
to see if your job actually has datasets attached?
Posted: Tue Oct 07, 2014 2:30 pm
by ArielRauch
what do you mean by:
all the fields which are in the submit points?
Posted: Tue Oct 07, 2014 2:35 pm
by ArielRauch
you are right.
there are no datasets with this job.
How can I prepare a job with datasets - I thought by switching the option "strip unique name" to no I keep all the metadata together with the pdf
Posted: Tue Oct 07, 2014 2:37 pm
by tz8
what exactly do you mean by that? _where_ do you do the scripting? In SwitchScripter? And you copy the data over into it?
Posted: Tue Oct 07, 2014 2:39 pm
by tz8
ArielRauch wrote: you are right.
no, you can't transport metadata like that, SwitchScripter doesn't work with the job database of Switch!
If you need the resulting XML file from your order entry point do a "export metadata" on "Order" and use this as the metadata backing file in Switch Scripter
Posted: Tue Oct 07, 2014 3:08 pm
by ArielRauch
I did what you said and received:
10/7/2014 16:05:22,Assert,Control,,,,,Libxml error 1549: 'failed to load external entity "" ' in file '' on line 0
Btw, when I am running the script in a flow I even do not receive the log messages.
