Is there any other way than Acrobat to convert JPEG to PDF?
	Regards,
	Aleksander
							JPEG to PDF
- TOP CONTRIBUTOR
JPEG to PDF
Imagemagick's convert tool
- TOP CONTRIBUTOR
JPEG to PDF
Safe how? It's reliable and can be used for production workflows. If you want JPEG PDF then it maybe better to use a different tool to avoid uncompressing and recompressing JPEG data.
						JPEG to PDF
You might be able to use Photoshop for this as well
JPEG to PDF
Photoshop will be fine if the number of images isn't really high. The application will be started for every image you're processing, this will be much more slower than the suggested solution.
Best regards,
Thomas
						Best regards,
Thomas
JPEG to PDF
dkelly wrote: Safe how? It's reliable and can be used for production workflows. If you want JPEG PDF then it maybe better to use a different tool to avoid uncompressing and recompressing JPEG data.
What other tools do you mean?
Aleksander
						JPEG to PDF
A bit expensive, but callas PDF Toolbox Server will also be able to do the conversion.
Best regards,
Thomas
						Best regards,
Thomas
JPEG to PDF
Until now I've tested a lot of files by Imagemagick.
I didn't see problems.
Remains to be seen
Thanks to all,
Aleksander
Remains to be seen
Thanks to all,
Aleksander
Aleksander
- TOP CONTRIBUTOR
JPEG to PDF
compendio wrote: Photoshop will be fine if the number of images isn't really high. The application will be started for every image you're processing, this will be much more slower than the suggested solution.
Actually the CS/CC applications are started and remain running after the first conversion. This can cause it's own problems.
