Multiple Unique IDs
dalbemil
Hi, I’m having an issue where Switch is adding multiple unique IDs to a job.
The example involves two files, both of which come from another flow through a folder called. The terminal folder in the previous flow does not strip the unique id.
One file is edited by the pdfToolbox software, the other goes through to the next flow.
Both files then enter the flow through the same folder. However, the one that did not go through the pdfToolbox software ends up with two prefixes (_0AEUP__0353W_xxxxx.pdf). The other appears perfectly fine (xxxxx.pdf).
The issue is quite bizarre as this wasn’t happening a week ago when I tested the flow. Today, after nothing has been changed it started happening
