Date stamp
abonsey
Date stamp
Post by abonsey »
How do I add a suffix to a PDF file in the format dd-mm-yy, then attach it to an email with a subject matter containing the same dd-mm-yy?
All I seem to be able to add is [Switch.Date:TimeZone=UTC] which contains hours, mins, sec etc which I don't require.
Thanks for the help
Date stamp
Post by gabrielp »
abonsey wrote: How do I add a suffix to a PDF file in the format dd-mm-yy, then attach it to an email with a subject matter containing the same dd-mm-yy?
Thanks for the help
Use the format attribute: [Switch.Date:Format="dd-mm-yy",TimeZone=UTC]
Use rename with suffix then a mail send with attachment and the subject containing the same string you included to rename as your suffix.
abonsey
Date stamp
Post by abonsey »
Thanks for that. Works fine.
