I am trying to use "execute command", but everything I tried failed, using Full Switch 09 on OS X 10.6.
The thing I wanted to accomplish is using switch to encrypt files via gpg before sending them to an ftp. So I tried the "execute commad" with the command "gpg" and the arguments for the input file, outputfile, the key to encrypt etc. But the best I got was an "ExecuteComandTemp" folder in the destination folder.
Anyone an idea how to get it to work, or did a similar thing?
Use execute command
There could be many reasons. Can you post the command string you are using.
I tried different things, here are two examples:
command or path: gpg
arguments (define single-line text with variables): --out [Job.Path].gpg --encrypt -r 'Test-Key' [Job.Path]
or:
arguments (inline value): --out "%2".gpg --encrypt -r 'Test-Key' "%1"
or:
- TOP CONTRIBUTOR
Is "gpg" program in your PATH? Try specifying the complete path to gpg, eg. "/opt/local/bin/gpg"
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Dwight Kelly
Apago, Inc.
dkelly@apago.com
your second approach
is the right one but you added the extension .gpg to the output path placeholder %2. This is wrong. Leave it away here and define the extension of the output file with help of the "Output extension" sub-property of the the Execute command "Output" property.
Regards,
Robert
Regards,
Robert
If I may, what are you using public key encryption with Switch for? This is the first time I have seen or heard of anyone doing so in a Switch workflow.
Got it to work:
command or path: /usr/local/bin/gpg
arguments (inline value): --out "%2" --encrypt -r "test@something.com" "%1"
output: file at path
works great, i also do the decryption with the arguments: --out "%2" --batch --decrypt "%1"
@mattbeals: I need it because all files must be encrypted that leave our company via ftp and also the other direction. This is because our IT doesn't support SFTP yet.
Great idea!
