Hi All,
I'm struggling with a problem for awhile. It's clear how to fetch specific data from an external dataset in PowerSwitch, but what if the data is a 'moving target'? Example:
var theDataset = job.getDataset("pi4"); // external dataset added by Callas pdfToolbox
var theOutputIntent = theDataset.evalToString( "/*/*[1]/*[4]/*[4]/*/*[4]" );
That's working fine, until the needed data is at the very same place. But in certain files the XPath should be something else, like "/*/*[1]/*[4]/*[5]/*/*[4]".
How can I query the needed info using the node names of the XML? Of course I know the node names, which are:
/report
/document
/resources
/output_intents
/output_profilename
Thanks in advance, kind regards,
Peter
Querying data from XML using node names
Hi Peter,
simply by using the node (and maybe also attribute) names within your XPath expressions
I don't have the structure of a callas pdfToolbox XML preflight report in front of me but relying on the information you wrote the correct XPath would be
/report/document/resources/output_intents/output_intent/output_profilename
As there might be more than one output intent in a PDF file you might access a specific one by using an index:
/report/document/resources/output_intents/output_intent[1]/output_profilename
or one or more pieces of additional information which uniquely identifies the node(s) within the XML like e.g. the PDF/X compliant output intent:
/report/document/resources/output_intents/output_intent[@subtype=GTS_PDFX]/output_profilename
Unfortunately this will not work because callas defines a default name space within their report XML files and therefore you will have to define a generic name space prefix within your XPath expressions:
/default_switch_ns:report/default_switch_ns:document/default_switch_ns:resources/default_switch_ns:output_intents/default_switch_ns:output_intent[@subtype='GTS_PDFX']/default_switch_ns:output_profilename
Regards
Robert
Regards
Robert
Hi Robert,
thanks for the quick help, it's working fine. I've never ever figured it out alone.
Kind regards,
Peter
Kind regards,
Peter
