Enfocus Community • Switch Client - Active jobs
Posted: Tue Dec 16, 2014 8:44 am
by ArielRauch
I am trying to understand how the filters are working:
I have a flow which is divided into a few independent flows. Each of those flow is handing the job to the next one. Of course I have removed "strip unique prefix" from the last folder of each flow in order to keep the metadata.
Now when I am looking at active jobs I see the job active in the first sub-flow although it either has already progressed or even finished.
Please enlighten regarding how to deal with the filters correctly.
Ariel
Posted: Tue Dec 16, 2014 3:24 pm
by gabrielp
ArielRauch wrote: Now when I am looking at active jobs I see the job active in the first sub-flow although it either has already progressed or even finished.
Is the job you're still seeing a different color? Maybe blue?
We add this to all of our filters and it makes them work as you would expect:
Posted: Wed Dec 17, 2014 12:19 am
by dkelly
What applications are using the most memory? In Activity Monitor sort by Real or VM Memory Usage columns.
