I would like to know, if when I change the time interval within a specific script whether it changes the interval for the whole switch instance or only for the script.
Ariel
setTimeInterval
- TOP CONTRIBUTOR
setTimeInterval
TLDR: per script instance
You can determine the behavior with this simple script. Create a flow that contains 2 instances of this script element. Name one of them "Instance 1", start flow and look at log entries.
if (s.getElementName() == "Instance 1")
s.setTimerInterval(10);
else
s.setTimerInterval(30);
s.log(1, s.getElementName());
else
ArielRauch
setTimeInterval
thank you!
