Selecting Images by Size
JPS
Currently, when selecting images by size, the dialog lets you select images for which the "width OR height" meet certain criteria.
This makes it quite hard to target images. For instance, you may want to select images whose width is above 300px but not images whose height is above 300px (unless of course their width does exceed 300px).
It would be better to have a pull-down that lets you select [Width / Height / Width Or Height] [Equals / Exceeds / Etc]
Another suggestion: selecting images based on their size in bytes. That can be very useful when cleaning up a document where you have extracted the assets and noticed that images in a certain byte range should be removed.
Basically, anything that makes it easier to target certain images.
Thanks in advance for your thoughts. :)
