When creating a PDF with Smartstream as a standalone using a csv that uses quotes and commas, they are both stripped out correctly and the PDF is good.
When using SmartStream though the Switch workflow the output PDF still has the quotes in!!
Anybody seen this? Any ideas how to resolve it??
Smartstream PDF creating leaves quote marks in!
Re: Smartstream PDF creating leaves quote marks in!
Did you test this on the same machine? Are you sure it's the same version of InDesign and SmartStream where you did your test as it is on the Switch Server?
Hi abonsey,
I faced this problem a couple of weeks ago and created a ticket at HP. HP created a new version of SmartStream designer to solve this issue.
I'm not at work now so I can't check the version, thought it was v10.2.12, I will check tomorrow.
It's no public release, so ask HP to get it.
Part of my playground:
- HP Indigo 10k, HP Indigo 7600's (full options), Highcon Euclid III, Zünd S3
- HP Production Pro 6.0.1, HP Production Center 2.5.1 beta, Apogee 9.1, Enfocus Switch 13u1 & PitStop Server 13u2.
Just checked, v10.2.12 it is.
