How do I unzip a batch of PDFs, and add info into xml to reflect new file list...?
Clive Andrews
I've been staring at this for a while now. If a customer uploads a ZIP, I can split the ZIP and xml with no problem. The xml that comes with the file is created by iDropper - and contains the file manifest that I use to build the archive hierarchy at the end of the flow...
So....
If I unzip a file and it contains multiple files, I guess I need to amend the xml with the new hierarchy - to merge it all back together and archive it...
Any suggestions anyone..?
Hi Clive, it appears that the iDroplet XML only contains the ZIP filename. Do you want to add a entry for each file that was extracted from the zip? Do you want to remove the ZIP filename also?
Dwight Kelly
Apago, Inc.
dkelly@apago.com
Clive Andrews
That's exactly it Dwight,
A normal iDropper XML would have
9.pdf
10.pdf
11.pdf
12.pdf
etc....
No zip - that should be discarded. I guess I'm back in the realm of my nemesis "Mr Scripting"...
