variable
kmcrae
variable
Post by kmcrae »
the variable [Stats.PageHeight] the result is in "point" size i want the result in "inch" size?
Harald Mahrer
variable
Post by Harald Mahrer »
as I'm from Austria I don't know the conversition factor from points to inches, but I got a small script-expressions from rzacherl which helped me to convert from points to millimeters. This should work for You if you just change the "0.35277" to your conversion factor and the Stats.MediaBoxWidth to the Stat You like to approach. You can skip the + " mm" in the end, if you do not want to attached the unit. You copy and paste the lines below to the "scripted expressions" editor where You need it (eg for the standard value of metadata field)
function convert() {
var MBpt = job.getVariableAsNumber( "[Stats.MediaBoxWidth]" );
var MBmm = Math.round( MBpt * 0.35277 ).toString();
return MBmm + " mm"
convert();
I hope You can use this.
Best regards from Vienna.
variable
Post by dkelly »
The conversion points to inches is 1/72 or 0.0138888889
var MBin = Math.round( MBpt * 0.0138888889 ).toString();
return MBin + " in"
convert();
Dwight Kelly
Apago, Inc.
dkelly@apago.com
