Pitstop Pro action in PowerSwitch
Posted: Wed Aug 17, 2011 6:02 pm
We've been trying to run a Pitstop action in Power Switch that deletes the last page of the pdf file sent to it.
The actions that make it up are:
Select last page
Remove selection
Remove empty page
The action runs great in Pitstop Pro. When added to PowerSwitch it hangs and and sometimes brings all other processing to a halt. I've also tried to run the action in a pitstop server hotfolder to see if it made a difference. It hangs that up too.
The Error in PowerSwitch is as follows:
Error while processing file: -13, Pitstop Server CLI hung or crashed
Any ideas why this won't work in the automation when it works so well as a pitstop pro action?
Thank You,
Mike Winker
Select last page
Remove selection
Remove empty page
Thank You,
Mike Winker
