Switch client SDK
mostafa_hamdy
Hello all
I'm using switch client SDK service , with .net client and I connect to the switch server correctly and the get methods works correctly , but when I try to use the SubmitFile10 web method I get the following error message:The underlying connection was closed: An unexpected error occurred on a receive.” the code segment I wrote is as the following:
string[] iIList = service.GetFlowList();
Console.WriteLine("Number of flows in the system: " + iIList.Length.ToString());
Console.WriteLine("================================== ");
for (int i = 0; i < iIList.Length; i++)
Console.WriteLine(iIList);
string[] arrCheckPoints = service.GetCheckPoints(iIList);
string[] arrSubmitPoints = service.GetSubmitPoints(iIList);
#region SubmitJob
if (arrSubmitPoints != null && arrSubmitPoints.Length > 0 && service.GetFlowName(iIList) == "Mindworking Media Cloud")
SubmitEntry inEntry = new SubmitEntry();
inEntry.flowId = iIList;
inEntry.jobName = "inject_job2.zip";
//An indication of the origin of the processed job before it was injected in the flow; for example, a Submit point writes the absolute path of
//the original job (on the client machine) in this field
//inEntry.jobOrigin = @"C:UsersPublicPicturesAllblank.gif";
inEntry.jobOrigin = @"C:UsersMostafaDesktopinject_job2.zip";
inEntry.submitPointId = arrSubmitPoints[0];
//byte[] inSubmitData = File.ReadAllBytes(@"C:UsersPublicPicturesAllblank.gif");
byte[] inSubmitData = File.ReadAllBytes(@"C:UsersMostafaDesktopinject_job2.zip");
try
Console.WriteLine(service.GetFlowName(iIList));
//Oservice.BeginSubmitFile10(inEntry, inSubmitData, new MetadataToFillClass[0],callback, asyncState);
service.SubmitFile10(inEntry, inSubmitData, new MetadataToFillClass[0]);
//Oservice.EndSubmitFile10(_result);
catch (Exception exc)
Console.WriteLine(exc.Message);
break;
#endregion
#endregion
result = service.CloseConnection();
System.Console.WriteLine("CloseConnection result: " + result);
finally
System.Console.ReadKey();
public static bool ValidateServerCertificate(
Object sender,
X509Certificate certificate,
X509Chain chain,
System.Net.Security.SslPolicyErrors sslPolicyErrors)
if (sslPolicyErrors == (SslPolicyErrors.RemoteCertificateNameMismatch | SslPolicyErrors.RemoteCertificateChainErrors))
bool ignore = true;
foreach ( X509ChainStatus status in chain.ChainStatus )
ignore |= (status.Status == X509ChainStatusFlags.UntrustedRoot);
return ignore;
else
return false;
public static bool TrustAllCertificateCallback(object sender, X509Certificate cert, X509Chain chain, SslPolicyErrors errors)
return true;
please if any body uses the switch client SDK and faces this problem and can help me please send me
regards
Mostafa
