Sort File by Mac Label
Danny
Post by Danny »
Has anyone had sort files by the color they are labeled? We are running PowerSwitch and I think this would have to be done using applescript. If anyone out there has had to do this or knows how I could write this I'd appreciate the help.
Basically, all I want to do in Switch is to move any file labeled Red one out going connection and send everything else down another connection.
Thanks for any help in advance,
Danny
Post by dkelly »
Hello, the following Applescript retrieves the directory contents sorted by label. You would have to modify it to get the directory name from Switch, instead of asking user, and process its output back into Switch.
set original_element to choose folder
set AppleScript's text item delimiters to {return}
tell application "Finder"
try
set sort column of list view options of original_element to label column
set contents_list to entire contents of original_element as text
on error
set contents_list to {entire contents of original_element as text}
end try
end tell
Sincerely,
Dwight Kelly
Apago, Inc.
dkelly@apago.com
