Hi
I have a application that gives me a 7zip password protected file. I have to extract it, edit some files inside and then compress again exactly like it was.
Everything is working fine, except when compressing the files again, I cant compress them to the root folder. let me explain.
Say I have a folder named "test", which contains loads of files, which I now want to compress. the compressed file must be named "test" as well, and all the files must be directly under that zip folder.
So here is what I do:
I use the Execute command tool
settings like this:
command or path:c:7zip7za.exe
Arguments:a %2 %1 -pp2p100
Output:file at path
Copy input job:yes
Output extension:.7z
Now this works 100%, except it creates another subfolder under the zip folder.
example: test.7z now contains a folder test, with the files under that...I dont want the extra folder....now when I try to do this at my arguments:
Arguments:a %2 %1*.* -pp2p100
(I just add the *.* as this works when I work directly in the command line interface), then I get no output at all.
Im sure I am missing something really stupid, but just cant seem to find my problem.
Any help will be great
Thanks!!
Braam
