Can Switch make a mail, where the path/url is in?
Jgandersen
I will make a flow, where i put a PDF in, and i down sample it to 72 dpi. after i down sample it i put on a FTP server, and I make a mail where the path/url are in the mail, so the customer can download the PDF, on the FTP server.
Can Switch make a mail, where the path/url/(download link) is in?
Jens Andersen
Clive Andrews
You'll need to have something in the xml/job info to define the output path. This can be used as a variable to write the file (set hierarchy path) - but you could write that into an email too, prefix it with http/ftp...?
How would you intend to get the destination directory into your flow?
