Enfocus Community • SFTP Download using Switch Execute Command
Posted: Sat Mar 19, 2016 8:36 pm
by msierra
Has anyone successfully used the Execute Command to send args to a ssh command line utility to download files? I'm attempting with Bitvise SSH Client without success. I have no issues using cmd shell and I do understand Switch executes directly in os.
Re: SFTP Download using Switch Execute Command
Posted: Mon Mar 21, 2016 2:01 pm
by gabrielp
I haven't, but did you know that the standard "FTP receive" configurator supports SFTP?
Posted: Fri Mar 25, 2016 7:01 pm
by msierra
I was trying with Bitvise sfptc via Execute Command and finally got it to work. However as you indicated the easiest solution is to use "FTP Receive", which supports SFTP. Thank you for replying.
Posted: Tue Mar 29, 2016 8:50 am
by Terkelsen
Switch supports SFTP but seemingly not FTPS. Any ideas that could help up- and downloading to an from a FTPS-server?
Posted: Wed Apr 13, 2016 11:21 pm
by 3f8h.net
You may want to build LFTP or http://curlftpfs.sourceforge.net on your windows / os x box.
